Пример:
Ответ форумчан:  -Тема здесь
Добрый день господа. Есть ли у нас автоматическое запирание дверей при начале движения? Листал мануал два дня но так и не понял.
Большое заранее спасибо за ответ.
Эта функция запрещена директивой ЕС, так что в новых европейских машинах её нет.
Пруф с английского форума Кашкаев:
REF: 1-53SZ45
Dear Mr Grüssen,
based on your request from 04. 04. 2013, regarding information about the absence of "anti-hijack" feature in vehicle New Nissan Qashqai, we had received an answer from the Technical department of Nissan Sales CEE Kft.
The answer is as follows:
Removal of this feature is based on a new regulation, and vehicle new Nissan Qashqai is one of the pioneers not having such features, and all the rest of the manufacturers will follow this.
"Please note that there is an impact sensor to unlock the car in case of accident: a signal from the airbag unit is sent to the body control module to unlock the doors if they are locked at the time of a collision. BUT this system is not guaranteed to function in case the airbag or BCM wire is cut during an impact therefore we cannot get regulation approval."
Based on the above, no manufacturers are supposed to offer such feature from mid 2015.
 We hope this information has been useful. If there is anything else that you feel we may be able to assist with, or if you would like a test drive in any of our models, please do not hesitate to contact us at Nissan Customer Support on 800 23 23 23. You may also visit us at www.nissan.cz for further details on any of our vehicles and for a selection of e-brochures.
Yours Sincerely,
Klára Sobotová
Nissan Customer Service CEE
Изменено пользователем nikus
Погасли приборы (спидометр, тахометр), стрелки не крутятся. Все остальное, вроде как работает. Подскажите предохранитель - сам не нашел.
Спасибо!
Нашел. Поменял. Заработало.
От чего сгорел?
Неизвестно. Повторится - пойду к дилеру.
Подскажите. Возможно ли управление ручником только в ручную. По факту... выключаю движок, автоматом включается ручник.
Изменено пользователем FirstTu
Все, правку увидел
Изменено пользователем AlexRoz
Вариатор или механика? На вариаторе ручник автоматически не включается.
Механика
Возможно ли заблокировать все двери с пульта при открытом багажнике? Часто возникает необходимость погрузочно разгрузочных работ.
В наружней ручке багажника есть две кнопки, одна длинная которая его открывает, а вторая круглая она управляет центральным замком. Если при закрытом центральном замке один раз нажать на круглую кнопку то разблокируется только дверь багажника, если нажать дважды, откроются все двери.
У меня ручное отпирание кнопка одна.
С автоматической задней дверью это не работает, проверил.
Как это может не работать? Пользуюсь так как написал, с момента покупки. Плохо проверяете. Круглая кнопка на ручке задней двери есть? Она работает также как кнопки на боковых дверях. У меня настроено что при первом нажатии открывается только одна дверь, при двойном все остальные. Нажимать надо именно круглую кнопку.
Нажимал. Щёлкает чего то, дверь не подымается ни в автомате ни в ручную. Может если поднять дверь и нажать на кнопку (круглую) тогда заблокируются другие двери? Или мы вообще о другом говорим?
Важен сам процесс открытия задней двери без разблокировок остальных.
У меня стоит по умолчанию разблокировка ВСЕХ дверей.
Щёлкает как раз ЦЗ, в вашем случае открываются, вернее отпираются все двери. От нажатия круглой кнопки дверь подниматься не будет, для этого необходимо нажать основную большую. При моих настройках, при нажатии на круглую кнопку отпирается только задняя дверь, и когда её открываешь, остальные остаются запертыми. Когда с ключа багажник открываешь, тоже вроде бы салон заперт остаётся. Вобщем всё завязано на настройки ЦЗ при отпирании дверей.
Ребята вопрос. что купить, X-Trail T32 с комплектацией LE 2.0  по цене 1 700 000 или X-Trail T32  с комплектацией SE 2.5 за 1 610 000 ? В комплектации SE нет экрана и кругового обзора но есть 2.5 объем, а в LE нет объема но есть экранчик , плюс панорамная крыша, но я его не хочу, мне просто с экраном хотелось мафон.
В LE нет экрана. Он есть только в LE+.
Да и цены уже ниже чем вы сказали.
У LE еще и фары интересные
Подскажите, а что начинает бурлить под торпедо после каждого открытия любой двери у не заведенной машины, так громко и порядка 6 сек.?
А если купить то, что хочется и поменять "мафон" на другой с экранчиком?
